Just copied a site from one server to another. In the admin area all the labels are in square brackets (and occasionally in Danish). Any ideas?
Annoyingly, I know this happened before (when I moved the same site the other way, but cannot remember the resolution)
Hi Tony
Could it be that you for some reason are missing the language files in the /umbraco/config/lang folder?
Not so much missing as conflicted by Subversion. But, that's fixed that
Ah yes, subversion can really mess things up sometimes.
Glad to hear you got it solved.
Upload image
[Indhold]
Hi Tony
